Unkown issue between the filament tube and printcore
Posted
· Unkown issue between the filament tube and printcore
Three things. It's probably one of these 3 things.
Make sure your third fan is working - the one on the back of the print head.
Check your retraction distance on your printer. It should be 4.5mm. If it's more than this you can get the issue you showed.
When inserting your bowden - it's very common for it not to go all the way into the white teflon part. From the photo I can see you have a solid aluminium spacer above the white teflon so it's hard to see what's going on so you have to do it by feel. The older printers have a spring instead of that metal spacer so you can see what's going on. Also make sure the bottom of the bowden is cut "square". Meaning perpendicular. It's okay to cut 2mm off the end of your bowden twice to get it square.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
