Thanks!
I was wondering if it was only for Mark2 because I believe that folder is there before the Mark2 upgrade stuff? (I didn't put it there.) It also has other Ultimaker .cfg files/folders as well.
Edited by CCA1Thanks!
Edited by CCA156 minutes ago, gr5 said:@tinkergnome ??
Nope - i'm lost...
@CCA1 you wrote "Resources" - that's in the Cura program folder on your harddrive, right? Wait... doesn't matter: there are no predefined .cfg files in the Mark2 definition files.
If one creates a custom profile in Cura, it will get this extension, but those are not stored in the program folder, but in the config folder of the current user. And the config folder has no subfolder "Resources"...? I must admit, that I've only experiences with the Windows version of Cura, it seems to me that you're talking about something completely different....
How about one or another screenshot? That could be helpful....
Anyone?
Well... you said you made a fresh install of Cura on a new hard drive and this subfolder appeared by magic - through no fault of one's own...?
Whatever: i doubt that Cura has interactive import or export functions for these kind of files.
I have no clue, where these files come from or how Cura assigns settings from there, sorry.
Thanks for the attempt Tinkergnome. I will try to explain better in case someone else can chime in...
Cura 3.2.1 has a folder inside it called "resources"
Inside that they have a folder called "quality"
The Mark 2 updates have nothing to do with this folder. They only use :
Definitions
Extruders
images
scripts
variants
So that leads me to believe the folder "Quality" is there for everyone. Inside this folder are many different folders, along with a small handful of .cfg files not in a folder. Each folder contains many different .cfg files. One of the folders is called "Ultimaker 2_mark2" I did not put this folder there, and do not know where it would have come from if not everyone has it? Even if everyone else only has the OTHER folders, my question remains the same....
How do you implement these .cfg files?
I hope this clears things up. Sorry for any confusion.
Thanks,
- Jason
Edited by CCA1anyone else?
Nobody knows how to use these config files? Just double checking before I go straight to Ultimaker for support.
gr5 2,210
@tinkergnome ?? CCA1 - I'm changing your title to mention mark2 so people with that upgrade will notice this post.
