Thank you @ghostkeeper for explaining/showing it.
Am I right to assume/say that this wipe is of no use for an UM3 as the other nozzle is lifted out of the way ?
Well, no. Depending on the material it might ooze that much the ooze length is longer than the z offset. And then it leaves that trail on the tower and not on the print itself.
Indeed, I believe the Ultimaker 3 has it disabled for most materials (like PLA) but enabled for the more flexible materials like PP which ooze a lot during stand-by.
ghostkeeper 105
Still seems to work fine. Here's how it works:
As you can see, it moves the nozzle to the side of the prime tower, which is supposed to wipe the stand-by nozzle off.
Edited by ghostkeeperLink to post
