Posted · Cura Connect Auto level not performed?
When print jobs are sent to printers Via Cura-Connect the printer will auto-level and then start the print. However if the error: height difference exceeds realistic values, appears the printer will wait for you to confirm.
With a normal print you would just restart the print after removing any debris from the nozzle, or just start it again and it will normally work. With Cura-connect you hit confirm, and then it attempts to re-start the print, it says auto level on the screen but instead goes straight to starting the print without performing the level check? Is this normal, or intended behavior?
Thanks,
