Hey folks,
I resolved the problem. Maybe someone has the same problem. So here is the solution:
I installed Cura on another Computer and tried it. On this machine everything worked fined with the default settings. So I enabled all settings and compared them with the settings on my primary computer. I noticed that the initial layer temperature was always 20°C hotter than the normal temperature (This setting was hidden). In my Case 230°C for the initial layer was to hot. When the printer began to retract about 20 (!!!) layers later, suddenly liquid filament dropped out and after this I had underextrusion the next few layers.
I have no explanation why the initial layer temp was alway 20°C more. I reinstalled Cura and deleted all corresponding files. Now its working like a charm
But really, really interesting that a to hot temperature can affect the print even 20 layers later....
Brulti 177
Hello,
Could you post your model here? That way we could give it a try ourselves and see if we can find what the problem is.
