First extrusion after changing e-steps is a mistery
Posted
· First extrusion after changing e-steps is a mistery
When you first start a print the extruder could be at any position. So you need to do a G92 E0 after the M92 but before you first move the extruder. Not only could the extruder be in a random position but also I think it stores the position internally in *steps*. So anytime you change steps/mm you need to do a M92.
In addition consider doing a M500 which will store the M92 steps/mm value permanently. Then you can get rid of that M92 command from your gcode start script.
gr5 2,210
More details here on gcodes: http://reprap.org/wiki/G-code#G92:_Set_Position
