Thanks for your answer.
So your recommandation is to have a third part (like a local server) to manage the communication between the website and the UM3 ?
Some sort of VPN solution would be much better than opening up your UM3 to the world. It does not have to be "3rd party".
AWS has VPN connections specifically for this:
https://docs.aws.amazon.com/AmazonVPC/latest/UserGuide/VPC_VPN.html
I agree with ahoeben, only do this if you are sure of what you are doing.
Thanks for your answers !
I will check the user guide for VPC VPN
@arnaudcosson
How did you end up?
Would you like to share your research or any solution here as I am looking for nearly same sort of solution?
That would be really great help!
ahoeben 1,968
Unless you know what you are doing: don't.
The UM3 firmware is not designed to be secure enough to face the internet. Unless you want your printer to be controllable by a random script-kiddie, do NOT connect your printer directly to the internet.
