25 minutes ago, Technofrikus said:I am also looking for a solution to this. I will probably just make custom profiles and import them by hand to the other computers. But a solution via dropbox or easier even per network share would be awesome. Especially since Ultimaker is geared towards businesses and this is probably a useacase that comes up often, I guess. At least in our company it is a problem at the moment. Also a long time in the making: ?
You could the new Backups plugin in Cura 3.4. It's not focused on sharing, but it works (login with the same account on multiple machines). As @nallath indicates, we are working on actual sharing behaviors as well.
- 1
nallath 1,123
This is a feature we're working on. Currently it's a bit tricky to share profiles between cura instances, which we hope to solve.
As for the disapearing profiles, I can't really say why. Could you share your log files?
Technofrikus 0
