It is 0.25mm not inch (just trying to avoid confusion).
In order to test if the nozzle is blocked, you could remove the bowden tube at the head, heat up the nozzle to 220C and push some filament by hand into the nozzle (from the top). Make sure to move the head to one of the four corners in order to not bend the smooth rods the head moves on when applying pressure.
If nothing comes out, the your nozzle is clogged and you need to unclog it.
Another reason could be that the nozzle does not heat up properly. The temperature sensor might got loose and report wrong temp values. Or it might be broken too.
gr5 1,872
Is line width set to 0.25 (or smaller) in cura?
What do you mean it won't work at all? Does it prime? Maybe something got into the nozzle - I'd do a cold pull. Are you familiar with cold pulls? Read up on these.
neatgadgets 0
The nozzle blocks and won't feed through any of the filament. Yes it has been set to 0.25in cura.
