Posted · z stop problem
here is another problem that i am having. After a bed leveling and the bed goes down I get a message that the z stop is bad. Power down and power up and good to go. Minor problem but not right. I have a kit built um2+.  Z stop works fine under at all other times.
    It might be that the firmware thinks your machine isn't as tall as it is in real life.  If you have tinkermarlin you can set that value I think.  Is your machine significantly (10mm) taller than a standard UM2?
    Also, are you sure bits of plastic haven't fallen onto the switch?
