Specify auto0.g as the filename for gcode?
lordnimon
Posted · Specify auto0.g as the filename for gcode?
My printer looks for a file named auto0.g on the SD card to print.  Would it be possible to configure Cura to always use that filename, instead of what it does today?
    1 hour ago, ahoeben said:
    See http://github.com/ultimaker/cura/issues
    I don't think this has a high chance of receiving developer attention though, since it is such a niche feature for your printer. You can already type the name in the lower right corner (above the size indication)
    Can't change the extension, though.
    its the autostart in Marlin firmware, so basicly every printer that runs marlin firmware supports it, I would hardly call that niche, I use it on my Ultimaker all the time :)
