did you model this in SketchUp?
All the red areas in the solid and xray view are bad, like inside out.
here are more tips: https://i.materialise.com/blog/3d-printing-with-sketchup
Sketchup yes, though not my work. I suspected the model might be fishy so I tried to clean it up with meshlab. After I put that file up in my original post, I specifically did a Re-orient all faces coherently, but this did not seem to make any diffference, so now I put it through Netfabb and this seems to have fixed the problem. I’ll see if I can print it :-)
Thank you!
kai 1
Playing around further it seems this only happens when I put the model over on its side like that; if I retain it in the original rotation, the slicing seems to work as intended.
