Here's the STL for it.
Set the Skin Removal Width setting to 0.5 or less and the skin will be OK when using 4 top skins.
There is something weird going on though because if you set top skins to 3, then the skins are OK without using a small value of Skin Removal Width. But setting the skins to 4 makes it bad unless the above setting is changed.
2
Interesting. I will play with those settings tonight. Thanks for the response.
Outstanding!
Still no luck. With 4 top layers, 2mm skin expansion and .5 skin removal I still get no skin under the text.
Could you please post a 3mf file so that I can see what settings you are using.
kmanstudios 1,117
I just went with defaults on 0.2mm and got this:
Starts to lay down the CT5
Gets to a spot 5 layers later that starts the other top surface
And then prints around the debossed letters until finished.
Am I missing something here?
Below is the project file I created. 5 brownie points to whomever gets the pun.
UM3E_ct-alpha-5.curaproject.3mf
Edit: I just noticed that you are slicing for a hictop and not any UM printer. This means that there is a variance on what the slicer puts out. I think @smartavionics will be much better at sussing this out. Especially since he is a coder and may find wht the part in the hictop profile is missing to create that issue.
Edited by kmanstudiosI probably should have mentioned that from the get go. I use a Hictop (prusa clone). And the software is on a MacBook Pro.
i hope this is the file you need.
You need to reduce to skin removal width to 0.1 or less.
Actually, further investigation shows that the real problem here is the large value of Minimum Infill Area. Reduce that and the skin shrink/expand settings are OK as they were. I was the original creator of the Min Infill Area setting and it is now pretty much redundant because you can shrink/expand the skins which you could not back then. Also, looking at the Cura code which has been reworked by someone else since I worked on it, it doesn't appear that the Min Infill Area setting does what I would expect any more. I recommend setting it to 0 now.
1
1
Sounds good. I’ll try that tonight.
burtoogle 506
Hi, could you please post the model for us to look at? Thanks.
