Our Bolt system also came with Simplify3D as it is the standard for bolt unit. Cura most likely can handle the specs but I couldn't find any information on how to set up the unit for IDEX configuration in Cura. Although, BCN3D Sigma IDEX printers are similar to Bolt and they have a profile for Cura. You might be able to tweak their settings and use it for the Bolt.
ahoeben 1,965
Can Cura be made to work with the leapfrog Bolt Pro? Highly likely. Will it work with it out of the box and let you use all its features? Probably not.
Note that Cura 15.04 is ~3 years old, and has fairly rudimentary support for multi-extrusion. Cura 3.2.1 is the current version, and has much more elaborate support for multi-extrusion.
