Avoiding printed parts - dual color
Marcos T
Posted · Avoiding printed parts - dual color
Hello,
As can see in the picture, using dual color, if the noozle do not avoiding printed parts, colors unwanted mix in nozzle ooze getting a bad result,
What can I do to solve this problem using cura 3.3.1?
I already tryed combing no skin without success.
Tks
    • 2 months later...
    Is that a brim inside your prime tower, or is it somehow doing 1 material on the inside and the other on the outside of the tower?
    Having the same issue and I have also no solution up to now...
    Z-hop is a first shot in addition to combing, but my impression is that combing or "stay inside a part" is also not working propperly.
    Posted (edited) · Avoiding printed parts - dual color
    Yes... I think the same as I can see the results even trying a lot of configs trying to avoid that problem.
    Using single color this issue is a little bit ugly in result but is not expressive like using dual or multi colors does (my picture show how this situation can be expressive to a bad result at all, using dual colors)
    Tks to add you reply in this topic.
    Edited by Marcos T
    • Thanks 1
    The real issue is the printer needs to be aware of the second nozzle in a meaningful sense.
    Even so it's hard to eliminate. It's just a challenge with dual nozzle prints.
