yellowshark 153
I assume that when you say make the cylinder larger you are increasing the diameter, not just the height, yes? If so then I agree with @SandervG it is likely cooling but without settings or pics it is just a wild guess. You want your layer print time to be say at least 10secs if reducing your extruder heat does not work. If need be print 2 or more copies to achieve this (all at once mode).
It may be that you are going too fast with a small diameter, although you say you have reduced the speed - from what to what?
SandervG 1,512
Hi @Clancey , thank you for your post.
If you're not entirely sure about the technical term, it would be very helpful if you could include some photo's. Could you also add which printer you have using a tag? (you can find them under the title of this thread).
But based on your description, maybe the layers just don't have enough time to cool down? Have you tried lowering the temperature?
