Cura 3.3.1 Layer height
Posted · Cura 3.3.1 Layer height
Hi There
I was able to choose different layer heights for extruder 1 and 2... I just updated to 3.3.1 and now I cannot set different layer heights for each of them. Any ideas? Should I downgrade?
    8 minutes ago, DidierKlein said:
    I don't think it was ever possible to choose different layer heights for the extruders, this would cause crashes most probably.
    Well I am printing two different objects and I need two different layer heights...
    What?  You print the first object with the first nozzle and the other object with the second nozzle?  It would be MUCH faster to print the objects as separate prints so it isn't heating and cooling nozzles on every other layer.
