I print usually 3, sometimes 2 walls and both settings you mentioned are enabled.
But the printer prints the infill (before or after the walls) -let's say- separately from the walls.
Just wondered if the start or end of a perimeter (maybe both) coud be hidden eg. into the infill, so the possible blob it causes would be invisible and there would be less tinkering needed to create less visible Z seams..
I set the Z seam alignment to "closest", but it is still not exatly where the infill ended.
burtoogle 509
It's not a stupid idea at all. If you are using more than 1 line for the wall, just make sure the "outer before innner walls" setting is not enabled and the "optimize wall printing order" setting is enabled it will print the inner walls before the outers. Hope this helps.
