1 hour ago, t-squareddesign said:Do I have to upload 2 seperate CAD files into Cura,
yes. Then follow kman's instructions.
I think I got my left clicks and right clicks mixed up. Sorry about that......Left clicks select, right clicks bring up menus and options.
kmanstudios 1,120
If you are using Cura, then follow these steps.
1. Make your object ass the two parts needed to fit together. It is a good idea to make sure that the two parts share the same pivot point location.
2. Import each file into Cura.
3. While separate, it is to select each model and assign the nozzle to be used to it.
4. The left click and in the context sensitive menu, choose select all. Or, CTRL + A for select all.
5. Then left click again and go to the same menu and choose "Merge Models". Do not use "Group Models". Group models will not align them to each other.
Then slice away. :)
gr5 2,243
What kind of printer do you have?
