Posted · Gap in Breakaway
Hi
I write here because I'm using Breakaway and I can't remove the gap between the TPU and Breakaway (picture). As a result, The surface is not enough good.
I hope you can help me
Thanks
    That's a parameter called 'Support Z Distance', if I'm not mistaken. You can set it to 0 to have the Breakaway and TPU stick together, check in layer view to make sure. However, be warned that this may make it extremely difficult to remove the Breakaway without damaging the TPU, since they'll bond quite tightly.
    Try with 'Support Roof Line Distance' at a small value like 0.01. Since it's smaller than your printing profile, it should have virtually the same effect as having a 0 distance.
