Issue with Cura 3.3.1
KiloByte
Posted · Issue with Cura 3.3.1
Hello Everyone,
    I have an Ultimaker 3 Extended. I recently upgraded from Cura 3.2.0 to Cura 3.3.1. I sliced one model in Cura 3.3.1, and saved the gcode on USB. When i tried to print it on my UM3E,  I received an error message that " This print job is not suitable for this printer. Go to ultimaker.com/ER26" and after i clicked the continue option i received the message "An error occurred while processing this print job. Line nr =13." I aborted the print and went to ultimaker.com/ER26 page, as suggested by the printer, but there was not any mismatch in the printer, Print cores or Materials.
    I sliced different model, just to make sure, it was not because of the model,  but i got same error message.
    After that i sliced both models with Cura 3.2.0, with same profile, and settings i used in Cura 3.3.1. And this time i received no error on the printer, it printed without any problem.
    I have attached, photos of error messages, and also gcode file i sliced in Cura 3.3.1, if it be of any help.
    Please tell me if you know what can be possibly wrong?
UM3E_Clip1_V12.gcode
    Posted (edited) · Issue with Cura 3.3.1
    4 hours ago, Chuan said:
    Why not printing by wifi?
          I personally prefer USB
    And do you try this in other printer?
        Unfortunately I only have one printer. ?
    Edited by KiloByte
        • 24 replies
