It's possible to do this if you add a cuboid stl file that envelops these layers where you want a different infill setting. but if you want to do this more than 3 or so times it starts to get to be a lot of work to create and position all these cuboids.
14 hours ago, obewan said:I dont think his is in Cura,
In slic3r it is called 'solid layer every'
ah, maybe thats it, i must of seen it when seeing what slicer i like
7 hours ago, gr5 said:It's possible to do this if you add a cuboid stl file that envelops these layers where you want a different infill setting. but if you want to do this more than 3 or so times it starts to get to be a lot of work to create and position all these cuboids.
yea, it must of been a slic3r setting
obewan 37
