Are you running cura and printrun/pronterface at the same time?
If so, there are problems with that.
If not and you usually use UC, you might want to get a USB hub to increase the voltage power of the USB signals. Some people have found this to help.
No, with printrun I mean Cura's own printing window that opens when you hit the print-button.
There is no problem with powering camera, it works fine. The only problem I have is that Cura is not saving any timelapse movie file.
gr5 2,005
