architectural facade details
bigmodels
Posted · architectural facade details
After some trial and error with sizes I think I have come up with what works best for me with building details on the UM3. Attached a couple photos of before and after to show the end result.
For vertical extrusions out from the face of the building I use 0.6mm width due to my nozzle size, for internal thin cuts that indent into the model I use 0.4mm width and for horizontal indentations and extrusions I use a height of 0.2mm. Windows I usually cut in 0.5mm with a 0.6mm offset to show the window frames when possible and for the thin elements I extrude or cut in 0.2mm just to show the facade panels details, this 0.2mm just shows enough of a detail to make it readable. Sometimes in the models I can't show all the horizontal elements due to the 0.6mm size but am able to capture enough detail for a solid representation of the facade. This model was in 1:500 scale and took a solid 3 days to print. I am using Form Futura atlas support in a polybox, which has never given me any issues and standard Ultimaker PVA settings. The balconies and verandah were printed separately.
Hope this all makes sense.
If anyone out there has any tweaks so I can add more detail, I would love to hear it.
  • Like 7
Really nice, excellent print! How did you end up with those numbers, was it purely trial and error, or did you use a certain formula as a starting point / rule of thumb?
  • 4 weeks later...
  • 3 months later...
