Posted · Disable auto reset on UM2+
Hi folks,
I'm looking to disable the auto reset that happens when you open the serial port on my UM2+.
On the other printers I've got it was a simple case of removing the capacitor on the DTR line of the FTDI chip and then I can send commands to the printer and read back the status while printing from an SD card.
Is there a similar capacitor on the UM2+ that can be removed?
Cheers
Jamie
Yes, if I start a print from the SD card then during the print I open the comm port to send a M27 command for example, the printer resets.  I would like to open the comm port during a print to send commands without the printer resetting.
