I have already used the volume subtraction feature in solidworks and there are supposed to be holes in the part. (pictured below) They are not showing up in cura. I will reload the part and just try to print it without the solids. Is there any other way to create different colors in parts that are completely encased or am I doing it the easiest way?
The holes are in the main frame and then I made small cylinders that fit perfectly in the voids.
Thank you for your fast reply!
Edited by Caylamayla
gr5 2,230
This is what cura is supposed to do. Print what you tell it to print. Cura does not do volume XOR or volume subtraction.
Instead try to do this operation in solidworks - it might be called "boolean subtract". I've never used solidworks but it can definitely do this.
