Strangely, when I made that configuration setting visible it was zero and the prime tower then changed to this:
As the prime tower volume setting goes up, the black becomes more blue. At 2 it looks like this:
At a stab it looks like you're getting both "circular" and "square" prime towers at the same time. I'd suggest turning on ALL the settings, then carefully turning them off one at a time (or thereabouts) to see if some setting can't be turned off while hidden.
If that works, post what did it, perhaps they can implement the logic on the backend.
Just for the heck of it. Try to just move the object to print over a bit and see if it affects the slice as you see it. Basically wondering if there is some sort of artifact in your model.....
Don't know what caused it but after I restarted Cura the squares went away and I haven't seen them since.
nallath 1,125
What is the value of the prime tower pruge volume setting?
