Do you read C++, if so, here's the proof:
skirt_brim_config_per_extruder.emplace_back(
PrintFeatureType::SkirtBrim
, train->getSettingInMicrons("skirt_brim_line_width")
* ((storage.getSettingAsPlatformAdhesion("adhesion_type") == EPlatformAdhesion::RAFT) ? 1.0 : line_width_factor_per_extruder[extruder_nr]) // cause it's also used for the draft/ooze shield
, layer_thickness
, (layer_nr == 0)? train->getSettingInPercentage("material_flow_layer_0") : train->getSettingInPercentage("material_flow")
, GCodePathConfig::SpeedDerivatives{train->getSettingInMillimetersPerSecond("skirt_brim_speed"), train->getSettingInMillimetersPerSecond("acceleration_skirt_brim"), train->getSettingInMillimetersPerSecond("jerk_skirt_brim")}
Just kidding! How about this, let's play spot the difference...
So it looks from the code and the layer view that the brim is influenced by the initial layer flow.
burtoogle 514
Looking at the code, the flow for the skirt and brim is controlled by Initial Layer Flow setting.
Strijar 0
In this photo the flow for brim is 120%. Does this look like 120%? But the flow of filling (in right part) is 115%. That's like 115%
