Thanks - I'll experiment with that. May not be exactly what I'm looking for, but worth a shot.
I'd love to replicate the same bottom texture that a raft has. I suspect trying to model it will cause the slicer a fair amount of grief. I guess the other option is to graft the code from the bottom couple of raft layers.
gr5 2,210
Well there is a feature called fuzzy skin. You can enable fuzzy skin only on the bottom few layers if you want. fuzzy skin is very cool. If you set the values very small it is a subtle fuzz and yet can still hide layer lines.
Other than that I guess you would have to use the raft feature.
