? Thanks!
I just had the same problem: when I unchecked 'Brim only on the outside', print time went from 4h to days (the time varies wildly between tries: 12 days, 7 days, roll a dice substract 7 and add the age of the captain...? ) and the brim lines suddenly extend to infinity and beyond:
Cura 3.4, same problem on Win8.1 and Win10, printer is a UM3E and is alone, no multiple build plate enabled (someone mentionned it in the github thingie).
The problem does not happen in Cura 3.3.1.
Edited by Brulti
ultiarjan 1,215
yep. you definitely found a bug. it's a funny one also, I just tried and every time you toggle the "brim only on outside" button you get a new time estimate.
thanks, I reported it here;
https://github.com/Ultimaker/Cura/issues/4009
