Yes, I have noted you as one of the people to follow for imformation, as you seem to know what you are talking about. i have purchased a couple of things from your store in the past. :p
The gentleman update the thread and linked to it. he was talking about "memory issues" and linked to this thread: https://community.ultimaker.com/topic/15939-tinker-firmware-introduction/?page=3
I have not done a factory reset after installing 17.10.1, that is something I would like to try, but I might just go ahead and install 16.01
what I found weird was that there was absolutly nothing done with the firmware (minus the change in e axis steps) only a change in the feeder, then this popped up. I was running the firmware for several weeks without issue.
gr5 2,067
We'll I'm the gr5 he referred to but I don't know what guide was meant. I have a guide for underextrusion but this is something else.
So I strongly recommend you switch to tinkerMarlin 16.01 and also do a factory reset and set the E axis steps again. 16.01 is much less likely to hang with this "error stopped". I've never seen it personally and I have all sorts of tinkerMarlin versions and UM2 printers but the people who get crashes with tinkerMarlin usually get it with versions after 16.01. 16.01 allows you to change the steps/mm and has 90% of the same features as 17.10.
