But I have only the 0,4 nozzle.
Then you can not do spiralize of 1mm thick, because spiralize will generate a single-walled object. What setting have you set combing too in this print?
What is combing?
What is combing?
Dim3nsioneer 559
You can use a 0.8mm or 1mm nozzle and set the line width to 1mm for the spiralize mode which is limited to one line.
