Printing a Pipe with 1 mm wall thickness in best quality
Posted (edited) · Printing a Pipe with 1 mm wall thickness in best quality
Hello,
I want to print a pipe with 1 mm wall thickness and a 65 mm diameter in PLA or ABS.
In my fist try I saw that the surface of the pipe has many small interruptions. How could I fix this. The surface has to be smooth.
Is it possible to print the part with 1 mm wall thickness in spiral mode? In the normal mode the nozzle is turning around many times.
Edited by Produktdesigner
    Posted · Printing a Pipe with 1 mm wall thickness in best quality
    Then you can not do spiralize of 1mm thick, because spiralize will generate a single-walled object. What setting have you set combing too in this print?
