Skulpt Thibra3D
fntsmn
Posted · Skulpt Thibra3D
This year I worked for different months to create and improve Skulpt from Thibra3D, was a lot of fun and I think is something different on the market.
I will share with all of you my experience and suggestion to be able to have a great print with it.
In few words Skulpt how is name suggest is a filament that you can 3D print and apply small or big changes at the printed model just heating up the surface and using tools that are commonly used for sculpting or even only a screwdriver.
This was one of my first test with the material a pumpkin, unfortunatly the print didn't went that well but is skulpt so was easy to fix it (the material was still in a experimental stage)
1211590666_Photo25-10-2017092945.jpg.98aff09e2cc5674a6cfbb855da7b8991.jpg274524860_Photo02-11-2017143340.jpg.91b8c404237570ab8b657b13e531199b.jpg
I could made a better job with fixing the shape but I was still impressed on what could be done with the material.
My second test was printing something low poly and sculpt it to become high poly with a lot of details. I decided to download and print this low poly fox
788879390_Photo22-11-2017092412.jpg.04a53b2aeaac898d0b902ffd81237a51.jpg1927900654_Photo22-11-2017111511.jpg.ef8589be38dc8d2472f9971d70c9b373.jpg632413683_Photo22-11-2017152522.jpg.fe6f86e60b576266b5efcf2c49f9f0c3.jpg312271364_Photo23-11-2017115340.jpg.906133dd8bda6ea6e835862395c967b8.jpg
I started to be really impressed on what I was able to do with this filaments and understand a bit better what you can do and what is better avoid with it.
Example with the Fox the supports work out really well and they come out really easily and you can smooth the surface super easily, you will never be able to see any imperfection on the surface that usually supports materials leave, one small disadvantage is that is tricky to print for small details, because the material like to keep the heat, but at the same time this details are super easy to fix after the print is done.
Now that I was more confident with my settings and skills I decide to print Groot Bust
2080078107_Photo02-11-2017143601.jpg.40504d8e7c3f0356487736f8fdf7aff2.jpg525615479_Photo02-11-2017100836.jpg.73a08a8712d472f939b79275cc8767e3.jpg995052891_Photo02-11-2017101650.jpg.d5bb1a50061b075051c7d2bcbdb21e78.jpg1917569035_Photo10-11-2017181018.jpg.25703e279287703011c584e52dcd9956.jpg
Another fantastic print! Support material was great I increased the detail, smoothed the surface and then Painted without any need of sanding the surface,you will never see the layers of printing and when the model cool down it become really solid and doesn't not feel like a 3d printed object.
At this point the material was really stable and working perfectly so we proceed on play more with the color and just finalize the material to make it ready for the market so I decide to make a big and long print on my Ultimaker 3. I decided to print my head, the print took around 70 hours to finish and I used the following settings:
Extrusion Multiplier: 1.21
Retraction Distance: 0 mm
Layer Height: 0.2
Top Layers: 15
Bottom Layers: 5
Outline: 7
Infill: 50%
Internal Fill Pattern: Grid
Brim: 35 Outlines
Extruder Temp.: 205
Heated bed: 60° only for the first layer then 45°
Fan Speed: 100%
Speed: 50 mm/s
134272472_Photo17-02-2018144720.thumb.jpg.e96f50c8d87478bb67d8bf2d7eef5120.jpg246386752_Photo19-02-2018085347.thumb.jpg.2d9e24341e627bb8e0557ecf336c1cc6.jpg778908509_Photo19-02-2018231743.thumb.jpg.dbaba655338c677f57235f537cb7e309.jpg
The spools that I used for this print wasn't the final product but we was still playing with the color this is why you can see some inconsistency.
After I removed all the supports I started to increase and add all the hairs details.
To add details is pretty easy you can use 3 main way:
- Hairdryer : Take a bit of time to make the material soft but you avoid to over heat it and maybe cause some small bubbles on the surface
- Heat gun: Take few second and you will be able to sculpt the material but be careful to don't over heat the surface too much
- Hot water: this method is great but make it more difficult to localize the heat in only one part of the model and can take a good amount of time before you can sculpt the model.
15465228_Photo20-02-2018184358.thumb.jpg.3ea13b07c9a508ce85f4ec9ab8b4dc42.jpg426411733_Photo20-02-2018185649.thumb.jpg.cd4062576d289b1c88eb55a1ff2b1c70.jpg351886287_Photo21-02-2018141710.thumb.jpg.f3ac3b01d4a6c534740bb05f0fee6baf.jpg30704877_10215617600902468_7257989378755715112_n.thumb.jpg.ee0330823c08f610a53258a736dc936c.jpg
I personally really liked work on this project at work! You can check too this short video that I made to give more information about this filament.
I'm happy to reply to any question about this Filaments! I will try to be active on this post.
30704877_10215617600902468_7257989378755715112_n.jpgPhoto 23-11-2017, 11 53 40.jpgPhoto 22-11-2017, 15 25 22.jpgPhoto 22-11-2017, 11 15 11.jpgPhoto 22-11-2017, 09 24 12.jpgPhoto 02-11-2017, 14 33 40.jpgPhoto 25-10-2017, 09 29 45.jpgPhoto 10-11-2017, 18 10 18.jpgPhoto 02-11-2017, 14 36 01.jpgPhoto 02-11-2017, 10 16 50.jpgPhoto 02-11-2017, 10 08 36.jpgPhoto 17-02-2018, 14 47 20.jpgPhoto 19-02-2018, 08 53 47.jpgPhoto 19-02-2018, 23 17 43.jpgPhoto 20-02-2018, 18 43 58.jpgPhoto 20-02-2018, 18 56 49.jpgPhoto 21-02-2018, 14 17 10.jpg
  • Like 3
On 7/18/2018 at 12:17 PM, kmanstudios said:
Once sculpted, is there a way to lock in the details permanently without worrying about it getting damaged or such?
After you heat up the surface and let it could down it will become really hard and of course the layers bounding is great. If you want to avoid that it will change shape I will lock it using a thin layer of Epoxy resin.
    1 minute ago, kmanstudios said:
    Afterwards, at what temp does it become soft again?
    You should eat up the surface around 60/80 degree to start to sculp it
    Just now, kmanstudios said:
    I am sorry, I meant after you sculpt it, you said it gets hard. Does it get soft again or does it bake in the details....sorta like annealing it?
    it will always melt around the same temperature but when you heat the surface the first time and you smooth it dipping your finger in some cold water and smoothing the surface and you let it cool down it will feel in a different way
    Thanks for the clarification ?
    No problem ?
    Hi I just bought some Thibra 3D Skulpt and am struggling to find out what the density of this material is as I am trying to set up a profile for it in cura so I know ruffly how much I need for my project.
    Posted (edited) · Skulpt Thibra3D
    Well, the manufacturer shows it on the product page in red and provides a technical data sheet that is offered in the download section...
    I would say: it's not that hard to find... (1.26g/cc - determined according to ISO 1183)
    Edit: ok, it's probably not the manufacturer, but one of the first results on google... ?
    Thibra3D datasheet: http://www.thibra3d.com/media/wysiwyg/producten/datasheet_thibra3D.pdf
    Edited by tinkergnome
    Thank you so much knew it might just be right in front of me ?
