set "travel avoid distance" to zero.
disable brim and skirt both!
details here:
https://ultimaker.com/en/resources/44677-maximum-build-volume-ultimaker-2-plus-ultimaker-3
There is no auto center nor auto rotate. The clip that holds the glass down is likely to keep you from using the full size. There is a keep out zone which is shaded.
1
SandervG 1,521
Hi @windwaver , welcome to the community! Could you also post a photo of your Cura settings / rendering?
Perhaps you have settings enabled that make the object too large like a brim, skirt, prime tower, prime blob.
