Just tried - the head isn't moving at all when I try to move it by hand - not even in the y-axis.
Dim3nsioneer 556
1 hour ago, chenobble said:Just tried - the head isn't moving at all when I try to move it by hand - not even in the y-axis.
When the printer is switched off? That would be very unusual.
Edited by Dim3nsioneerI can understand it not moving in one axis but both? Push hard enough to slide the printer around on the table - well 2X harder than that actually if it's a bit stuck. You had power off? You should be able to move the head in one axis by just using one finger of each hand on the sliding blocks.
I think you are going to take this all apart. I had one UM2 I repaired that required a hammer and vicegrips (set loosely) to get the brass tube bearing (hidden inside those side blocks) off of the side rod. There was some kind of stain on the side of the printer - I think someone sprayed polyethylene paint or something (or hairspray?) and it completely jammed up one of the 4 sliding blocks. I was able to clean it with paint thinner and the printer is as good as new now.
It could be one of many parts jamming it up and I don't think you will know unless you take it all apart. Don't take apart the frame - just the gantry. There are videos showing how to do this.
- 1 month later...
Hi gr5,
I am having the same problem as chenobble. The only difference is that the X motion is not moving. I can see the motor spinning and the belt is jumping over the teeth of the gear. I cannot move the X motion.
You said there are videos showing how to remove the gantry. Can you direct me to them or provide a link?
Thanks.
My printer had started giving off the same grinding noise and I was trying to follow the steps you guys had mentioned in this post; and now there is another problem. As soon as I turn on the printer it starts printing on its own.
Can you please help me?
I have uploaded the video on the following link:
https://drive.google.com/open?id=1plOdscqiaD9iZ7gG5l15u9OQdNqLHmaC
Dim3nsioneer 556
Can you move the head in x direction by hand when it is switched off? If yes, does it feel normal (compared to the y axis)?
Edited by Dim3nsioneerLink to post
