On 8/20/2018 at 8:22 PM, gr5 said:This might be available now. Not sure. You can split your cad part into two parts (2 STL files) - the portion that can be printed fast and the portion that should be printed slow. You can put both parts into build plate, set settings for each differently (over on the left side of cura) and then select both parts at the same time, right click, and there is some kind of merge or something in the choices.
Would end up quite complicated in some cases. I was hoping to ease that with a simple setting.
On 8/21/2018 at 11:14 AM, Dim3nsioneer said:Decreasing the acceleration and jerk settings should have a similar effect. Small features have a lot of direction changes and are therefore printed slower while long straight lines still reach a high speed. But please keep in mind that the extrusion rate might not be the same for slow and fast parts and small details might become thicker than wanted.
Decreasing the Jerk/JD and ACC settings affects the whole model, reducing speeds where they should be high.
I run 32bit system that monitors extrusion along the whole path so no worries there.
I print biiiig. Very big, but some parts have small details in the outer surface. The bigger you go, the more it means.
Dim3nsioneer 558
