+1
I had the same issue few months ago, and this wires was disconnected.
+1
Trying that now thanks for the suggestion.
So far it is looking good 10 minutes in and still going. Thanks for the help!
It's important to use the strain relief. Everytime the head moves the wires bend slightly and eventually the temp sensor wires tend to break first. You can alternatively use the alternate cable. If you do that, make sure you unplug both ends and plug in the other cable on both ends.
SandervG 1,522
Hi, Please doublecheck the red+yellow wire that is inserted in the screwterminal on your amplifier circuit board.
If they look fine, please take 'm out and secure them again. Most likely 1 of the wires is not making a proper connection.
