Under extrusion problem located
Makosjarks
Posted · Under extrusion problem located
Lately I've had a problem with underextrusion on my UM2.
Something was causing a lot of backpressure, i could hear the extruder skip or hop on occasion, but i was having trouble finding it.
After experimenting with extrusion temperature, different rolls of filament, extrusion speed, cleaning bowden tubes and extruder gears and housing, changing nozzles, still underextruding.
Changed heatblock and heater/thermocouple, still problem.
Then I re-took the hotend apart and found this..
Capture2.PNG.be5cc90460c0f576c85c3bbdfbbb780c.PNGSome plastic had gotten between the I2K spacer and the base of the stainless steel bit and hardened producing a constriction. I must missed this when exhanging bits.
In case someone else is running into the dark corners exploring under extrusion, here is one more stone to turn over : )
Mathias
