Thank you @JohnInOttawa. I also thought it was the humidity at first so I bake-dried and sealed with desiccant, etc.
But I think it's interesting that my PVA stops extruding at the same height regardless of the print size. (I have a larger print that also failed to extrude PVA at a nearly the same height level.) So now I'm thinking it might be Cura related?
JohnInOttawa 99
I understand you have kept your filaments in bags with dessicants. That might not be enough. How long ago was the PVA first used?
To my eye, it does have the look of humidity. I use a filament dryer, dried my PVA completely two weeks ago and sealed it with fresh dessicant. I could hear it popping as it printed today. One area of a support failed the same way as print #1.
Just a thought.....
John
