Hi nallath,
Can you please give me the path to Cura log file, I usually use the menu in UI to show the file but as I can't start Cura...
Thanks
Hi nallath,
Thanks
From the top of my head, see ~/Library/Application Support/Cura/3.4/cura.log
Edited by ahoebenYes that was my memories too but I have no "Cura" folder in my ~/Library/Application Support/ ?
I will try uninstall and re-install Cura
Very strange behaviour.
The Cura folder was there but not visible in ls or with autocomplete in terminal
In the Cura folder I had the 3.4 and the zip from backup
Cura Arnaud$ ls
3.0 3.4
3.1 3.4_20180911_141802.zip
I unzipped the zip, override the files and remove the zip file.
Cura now starts and I have the saved profiles from my colleague.
nallath 1,125
This shouldn't matter. But if you could share your logs, i can have a look at what happened (and maybe fix it)
