Strange noise in XY motion
fergazz
Posted (edited) · Strange noise in XY motion
Hi all!
After a strange noise during printing the Forbidden Watchtower by Kjai I paused, resume and paused again and quit this print. Looks like it also cause a layer shift:
Video_UM2(+)Noise_14seconds / google drive
What's going on here? By the way I'm using UM2(+) printer, Simplify3D v4 and thinkerMarlin 17.10.1 as firmware
1: Bearing problem?
2: Lack of lubrication on XY the axles? It's tought to move with printer shutted down.
3: Slicer problem? In preview looks fine. Firmware problem?
4: Belt? Everything seems in place.
5: None of the above ?
Edited by fergazz
*Forbidden Watchtower
    Posted · Strange noise in XY motion
    Make sure to power-cycle the printer. There was an inexplicable case where the print head made a sideways move during a print. Maybe this is related.
    You mentioned that it is tough to move the head by hand. Maybe the belts are too tight. You should definitely not move the entire printer around if you move the print head.
