Cura won't accept build volume
twiereng
Posted · Cura won't accept build volume
My Ultimaker 2+ has a build volume of 223 x 223 x 205 mm. My print is 203.2 x 203.2 x 196.85 mm. My Cura 3.4.1 will not accept this build volume. If I scale it down to 92 % it works. What am I doing wrong? Screen shot attached.
Thanks, Theron
        • 2 replies
