Yeah, 3D Coat made sense to me, I’m very impatient and perhaps a bit to intolerant when I try new programs. If I cant understand a thing and the menus look like something from a cockpit of an 787 then I’m off to the next. Tried Zbrush and that gave me that cockpit anxiety ?
I’m well aware of the term ‘steep learning curve’, but what can I say. Sometimes I go a few laps around programs and end up with one of those I rejected the most.
I realize I have a ton of new terms to learn, like the difference between voxel and mesh wich I understand is pretty much as basic as it gets ?. For starters I’m aiming at beeing able to clean up some scans that is beeing shared.
Just want to say that I very much appreciate your postings like this one, and many of your other postings too of course...
kmanstudios 1,120
That is UM White TPLA. It does print nicely.
And, thank you.
I hope you enjoy 3D Coat. I know I do. It has a lot of power and also has the ability to do mesh modeling as well as voxels. I just am very familiar with 3DS MAX and use that for my basic mesh/poly modeling needs. But the program is very tgood with being able to work in a flexible way.
Do not forget to look at Gumroad and do searches for '3D Coat brushes' or'3D Coat Alphas.' This will give you a lot of sources to download or cheaply purchase. Very nice stuff out there. Great time savers.
In the next part you will see how I had to use 3D Coat for boolean ops for the stand. And, that meant back into voxels from an almost completed model in 3DS MAX. It jsut solves that messy mesh boolean issue that plagues the mesh based programs. It is the curse of boolean ops in mesh. No mesh program is immune.
