Here is the project file (I think)
Hi @Kalveo, thanks for the project. I fiddled with a few settings and now the travels look less wild. I have set the combing mode to "not in skin" which has been reworked in the 3.5 beta release and now behaves as you would expect. If you are using an older Cura release you will still see travels across air.
- 4 months later...
Wonderful! How did you get it??? I'm having the same problem. Here is the file. Kind regadrs,
Pablo
@placho - read the post above yours.
burtoogle 514
Hello @Kalveo, it would be much easier to answer your questions if you could attach the Cura project file to this thread. Use the file menu save (or save as project in older versions of Cura).
