Not sure exactly why you need this but with the phone app you can remotely launch a print. At least when you are on the printers network. I do this using a VPN connection.
Though I never start a print remotely as I prefer to be around for the first few minutes I use it for monitoring and the ability to remotely shut it down. I even added a WiFi powerplug just to be sure.
Smithy 1,145
I am not aware of a "out of the box" solution, but one idea is to use an external script. If you are familiarly in scripting, you could use the API of the UM3 to check regularly if printer is online and start a new print.
The downside of this solution is, that you have to run a separate PC, Raspberry, whatever.
