FINALLY trying this.
Notes:
In the extruder file:
I think
"extruder_nr": { "default_value": 0 },
should be 1 as well, as in:
"overrides": {
"extruder_nr": { "default_value": 1 },
"machine_nozzle_size": { "default_value": 0.4 },
"material_diameter": { "default_value": 1.75 }
The other issue:
"0": "creality_cr10_dual_extruder_0",
"1": "creality_cr10_dual_extruder_1"
You need a comma between the two entries in that ... list? array? Thing with bendy brackets. ?
Thanks again, going to try this out.
ahoeben 1,968
Cura 3.5 has made it easier to change a single extruder definition to a multi-extruder definition, by requiring an extruder definition for the single extruder.
* Make a copy of the single extrusion definition (creality_cr10.def.json -> creality_cr10_dual.def.json)
* In creality_cr10_dual.def.json, change the name metadata and "machine_extruder_trains" metadata:
{ "0": "creality_cr10_dual_extruder_0" "1": "creality_cr10_dual_extruder_1" }
* Now you need to create those two extruder files:
* Copy extruders/creality_cr10_extruder_0.def.json -> extruders/creality_cr10_dual_extruder_0.def.json and extruders/creality_cr10_dual_extruder_1.def.json
* In extruders/creality_cr10_dual_extruder_0.def.json and extruders/creality_cr10_dual_extruder_1.def.json, change the id, and under metadata change the machine and position (position should be "1" for the second extruder).
AbeFM 35
OMG thanks for that!!!!!!
This is something I've been fighting for a long, long time, and more or less given up on. I'll try it out. Even the firmware can't seem to keep "is the second extruder #1 or #2" straight, but I think I can manage.
