Thank you, yes I already experimented and printed with infill, but instead of the whole cube be filled, perhaps it is possible to create an infill structure that matches the shape of the inset top shape?
Edited by mamoFor this sort of special cases, you would best design your own custom supports in your CAD file, I think.
What is the purpose of having the numbers on the inside? Even if you are going to print it transparent, and with a dissolvable support material, it will hardly be visible, if at all.
And if you print it closed, without openings, there is no way to get the support out.
Yes thanks for your tips and info, you're right, it is hardly visible.
gr5 2,333
You want "infill". Not "support". Play with infill settings. You might want to try the "gradual infill" feature to save time if you ever print something much larger.
