Ahhhh, on looking at the g-code again I did indeed find the 'zoffsetprocessesd' string at the very top and the actual offset adjustment way further down than expected at <Layer1> at a z height of 0.6 mm (0.723 with the offset)
The code is included. z-offset is 0.123. Cura 3.41
Thank you very much for looking at this!
I must admit, I am a bit mystified why anybody would NOT use this feature. I find it essential to fine tune adhesion and the only other alternative is going through the EPROM settings which is much clumsier
ahoeben 1,960
The plugin could very well be broken; it is one of those things that I made because it was so often requested, but that I don't actually use (or need) myself. So keeping it in a working state depends on feedback from users like you.
Could you save a gcode file with the zoffset set to a non-0 value, and check if it contains the string "ZOFFSETPROCESSED"? If so, keep searching, for ";adjusted by z offset". This would mean that the plugin is doing something, but possibly at the wrong location.
