I would definitely take apart the feeder and clean it out and look to see if something is grinding away. The white feeder on the UM2+ is quite easy to take apart (half way apart anyway if you keep going after getting the cover off the stepper motor for it will fall down). It could be the particles came from the filament spool and/or metal dust that fell into/onto the filament spool.
gr5 2,194
